I'm quite new to record players and inherited a Beogram 5005 from a grandparent so apologies for the lack of knowledge and correct terminology.
At some point recently my Beogram 5005 appeared to stop playing records properly. The needle wasn't getting in the groove of the record and so the sound was very crackly and jumped a lot.
I read about stylus pressure
Login to view
Login to view
Login to view
Beogram 5005 - stylus pressure too high?
Sorry I can't help much, I don't have a 5005 but from what you say, and the image of the gauge I'd say it is unlikely to be a stylus pressure issue and more likely an adjustment at the back of the tonearm. You might try and look for a service manual online which usually go through mechanical adjustments. If the issue is electronic then unless you are knowledgeable you'd best find a repairer.
EDIT, and are you saying that the issue is solved when you put the scale over 2g? In short, it won't damage the Beogram but it will wear the stylus faster and will cause wear on the records, especially if the tonearm has some other issue. I know back in the days when some "hifi" records players were exerting something like 10g! but generally today they never go over 2.
Thanks for the advice, etype76.
Yes, the stylus pressure seems to be over 2g.
I had a look at the service manual and it seems a bit out of my depth so I will bring to the local repair man.
Thanks!
Olie
More likely a "close to death" stylus…
Unfortunately, the guy I got to service the record player before has retired!
Does anyone know of and recommend anyone UK based who still services old B&O products?
