Brand new to the forum but not new to B&O. I had a Beogram 8002 for years but it didn't survive a lightning strike and was sold off for parts.
Some years later, missing the aesthetics of the 8002, I purchased a partially working unit in hopes of repair. I recapped everything and reflowed at least 30 solder points, many of which were obviously cracked. Most of the functions worked but the tonearm seemed not to sense position and a record would play for only about 30 seconds before stopping...
As part of the standard service I attempted to adjust the A & B screws for << and >>. Voltages at pin 4 of P5 and pin 6 of P5 were about 770mV instead of the recommended 620mV. I turned the unit off, adjusted each screw no more than a degree or two and now the unit is absolutely dead... not even a red dot on the display. What happened? It did not blow the power supply and no burning or popping. Zapped the microprocessor? I am essentially at the end of my knowledge to troubleshoot this... just when I thought I was accomplishing something. Any suggestions would be greatly appreciated. Radman.
Recently retired. Restarting electronics hobby that was on hold for years.
