Beogram CD 5500 right channel no sound
Hi B&O Fans, a new small project on my table. A Beogram CD 5500. After replacing the famous capacitor the CD runs now. But unfortunately only on the left channel. Cause i don´t have an oscilloscope  - is there anything else, i should take a deeper look at? I checked the solderings, but nothing obvious.   Best regards 69er
I would check the relay first. Perhaps the right channel isn't making adequate contact.
Hi quatttro, where is the relay in a Beogram cd? best regards 69er
Check the filter capacitors and their respective resistors for the opamps in the analogue output stages. Martin
