Can anyone recommend a tracking force gauge?
I have three Beogram turntables and I've been having trouble with one of my MMC4s.  I wanted to check the tracking force is right, so I bought a tracking force gauge. the one I bought (
Old enough to have gazed at classic B&O HiFi in Plumbs shop windows in the 80s...
You can get that one to work by removing the top platter and belt.
Thanks - I was able to remove just the top platter and didn't need to remove the belt or wheel- that did provide sufficient space to measure the stylus pressure.  Turns out it was spot-on, but I'm glad I was able to check it!
