Thx for any advice!
CD 5500 running hot! left side near back
I noticed my CD 5500 gets very hot to the touch, on the left side near the rear of the unit. There is plenty of airflow around it, I even have the stacked units on risers so there is a good 1/2" of clearance between them.
Does the motor need lubrication?
I can't think of what else could be generating so much heat inside?
I doubt its the motor as its on the right as is the transformer. My suggestion would be to open the unit per the manual at https://beo.zone/media/files/Bang-Olufsen-Beogram_CD-5500-Service-Manual.pdf and identify the specific component generating heat.
Two things if the transformer gets hot:
- Is it 220 or 240?
- Check power supply caps. I had a 5500 with a nearly shorted one (Sony branded) that made the transformer thermal fuse melt.
This might eventually happen to yours.
Leave the motors alone.
Jacques
Thanks guys!
I will reference the schems. It's 117v, North America version
I found some circuit board pics here, too:
https://lampizator.eu/LAMPIZATOR/REFERENCES/Bangandolufsen/Bang%20&%20Olufsen%20CD5500%20CD%20player.html
I see some caps and those 2 large things that look like solonoids?
Leave the large silver caps alone, and check the others that supply the different voltage rails.
Jacques
Here, replace those already.
You may want to buy a kit Login to view image
Jacques
https://lampizator.eu/LAMPIZATOR/REFERENCES/Bangandolufsen/Bang%20&%20Olufsen%20CD5500%20CD%20player.html I see some caps and those 2 large things that look like solonoids? The full CD5500 service manual (incl 120V US version) is available on the site for Silver and Gold members, if that helps! https://beoworld.org/manuals.aspLocation: Warwickshire, UK
Funny that I should still appear as a bronze member Guy, by the way ?
Jacques
Login to view image I'll raise it to Keith - I think there has been a fair amount of manual input required regarding membership status on transition to the new forum. EDIT: Now sorted thanks to Keith!Location: Warwickshire, UK
Cheers ?
Jacques
