Hello everyone,
I am very new to B&O systems, I have only just bought a pair of Beolab 18s which are connceted via cable and an RJ45/2x8pin adapter to a Besound Core.
Now I have auctioned a Beogram 4002. First I need to install a needle and mount an internal RIAA preamp (the "easy no soldering installation" thing). After that, I wonder what's the best way to connect the Beogram to the Core. As I notice, there is only a limited number of connection ports on the Core. Do you have any suggestions?
Also, I wonder what will be the best way to adjust volume: On the Beogram itself or via B&O App. Will the Beogram even show up as an external device?
Connecting Beogram 4002 to Beosound Core
Hi Mjoelnir
The BS Core has one input port, which is combined mini-jack analog and toslink.
In your case you will only need an adapter cable between the turntable and a male minijack connector.
There is no option to control the volume on a Beogram itself (the output is fixed) - this is done in the Core.
Once you have connected it there, the Core turns on to that input (i.e. autosense), when the turntable has started.
You can use the B&O app for volume controlling like with all other sources like B&O Radio etc.
The turntable will show up as an AUX-connected device.
You will not be able to remote control the turntable (pause, play etc) - that must be done on the turntable.
Alternatively you can control the volume with the Beoremote One, an Essence Remote or the Halo remote.
FYI, you are not limited to an internal phono preamp if you have trouble finding one. You can use and inexpensive Project Box or Schiit Mani and actually get better sound.
Thank you for your reply and your suggestions. As I am very knew to the audio world, could you perhaps explain to me why these preamps make better sound than an internal RIAA preamp? Is the difference big? I really like the idea of having one single device without a separate preamp including power cable etc., but I cannot estimate what the difference in sound quality might be.
Sound quality will be more a function of the cartridge and speakers you are using versus the preamp. To get an internal one you’ll need to spend around $400 where a decent external one can be had for $100+.
