Hi all!
I recently purchased a BeoGram 7000 black edition which we find gorgeous. It came with a MMC2. Unfortunately, my cable setup is not working flawlessly and it keeps producing a 50hz sound.
On one side of the living room, the BeoGram is located:
- Original cable with DIN plug
- DIN to RJ45 (provided by Steve)
- RJ45 goes into single wall socket
- RCA to DIN cable (provided by Steve)
- RJ45 goes into double wall socket
- The cable between both ends of the wall sockets, is a double shielded cat7 cable.
- The double wall socket is shared with another cat7 cable used for wired internet from the modem to a switch.
- I have connected the BeoGram directly to the Almando using Steve's cables. Everything works perfect. The problem is, there's no room to keep my BeoGram next to the Almando (see attached picture). It's supposed to sit opposite of the TV across the room.
- I disconnected the cat7 cable from the double wall socket and attached an RJ45 connector with a crimping tool. Unfortunately, the 50hz hum still persists.
