So, I decided to practice my polishing skills ??. First, I took my old BG dustcover and cleaned it with a mild polish like TG in the YT video:
Login to view image
You may see the difference between left, right (both cleaned) and middle area.
Now I cleaned the whole lid and taped the mirrored part to the front:
Login to view image
Login to view image
Better, but a lot, lot of scratches still left.
After that I watered it:
Login to view image
And then, I took a deep breath. Starting with sandpaper 1000:
Login to view image
First round - ever - done! Now, cleaning off the plastic fragments:
Login to view image
The surface feels very smooth, but I guess, the sanding image should be more regular? A long way to go.
Login to view image
Login to view image
The second picture reveals an indentation I most likely will not get covered. And I have to get me a buffer for the finish.
This is it for today. I hope, I can restart tomorrow, will keep you updated.
Kind regards,
Rolf
