Following up with some additional information. Found a post on Beolover about checking the power when the 8002 shows no sign of life. They recommended checking the 5V regulator first, but I'm not sure on how to measure it. Any detailed instructions are welcome on testing the 5v regulator or the power in general. I have basic soldering skills and know how to probe with a multimeter, but my knowledge ends there. Login to view imageLocation: Pennsylvania, USA
- Michael ArchambaultI appreciate the advice, Glitch. I left the comment about not worrying about the soldering in my photo because I had an issue with my solder station and consistent temperatures. To show, I've retouched the board now that the station problem is resolved. I've also included photos of my recap job. Is it perfect? No, not at all, and I will keep practicing (I struggled a bit with the wire not being though-the-hole)! But it's nowhere as bad as you might have thought initially. :) Login to view image Login to view image Going back to the issue, I triple-checked my work: I looked for potential cracks, made sure the caps were installed with the correct polarity, and used a meter to test for continuity to ensure solid connections to points down the circuit— everything looked good. I also went through reflowing joints for all the major connectors. I think a component may have failed from excessive heat (I mentioned my solder station issue before), and I wonder if a cap has gone. My plan at this point is to ensure power is flowing correctly, and I've been told that it starts with the 5V regulator. Any assistance or detailed steps to ensure the PSU delivers voltage and electricity flows would be welcome. I had to move the metal shield on the transistor I pointed out at one point, and I wanted to ensure the component is now working.Location: Pennsylvania, USA
- Michael ArchambaultHey Glitch, nice eye there! I've gone ahead and redone C24 as shown below. Another oddity that I noticed with this cap is that the board diagram shows reversed polarity compared to how the original was installed. Both the original cap and any repair work I have seen the other way. Thoughts? Login to view imageLocation: Pennsylvania, USA
- Michael ArchambaultThanks, Glitch. I tried both methods shown below, and neither worked. I've left it in the 'A' configuration that you suggested. Here is the 'A' configuration that you suggested. Login to view image Login to view image Here is the 'B' configuration I see for other repairs, such as Login to view image Login to view image If I did want to test the power supply to ensure everything is working fine and test the 5V regulator, would you be kind enough to specify exactly where I should place my meter probes? Beolover provides a good guide for measuring across caps for the power supply, but ILocation: Pennsylvania, USA
- Michael ArchambaultPlease Log In to Reply
or![]()
