Replacement chrome plate for Beogram 4500
Do any kind souls know whether replacement chrome plates are available for any of the Beosystem 4500 components ? My Beogram 4500 has a very small ding on it, which is spoiling my enjoyment !
Thanks in advance
Jonny
I have tryed to sand it down and polishing it and the result was disapointing for my Beogram 3000. Best is to find another lid and I didn't find it.
For the best time being I did put this on it and it looks almost like new. Maybe find the right color wrap for your Beogram 4500.
Before:
Login to view image
After:
Login to view image
brushes-aluminium-zilver-wrapfolie
https://www.premiumvinyls.nl/brushes-aluminium-zilver-wrapfolie.html
Groet, Jan.
I found a better solution. A replacement.
Top Plate for dust cover Beogram 3000 3300. https://www.dksoundparts.com/product/top-plate-for-dust-cover-beogram-3000-3300-anodized-aluminium/
How to remove the old plate? Heating it up with an heat gun?Please Log In to Reply
