I had to dismount the tonearm to fix a broken piece of plastic but did not pay attention to the 5 wires which is soldered onto the small board.
How on earth do I make sure i solder them back on correctly?
I quess I cannot just connect them randomly.
Maybe one of you guys now how the 4 sockets are to be soldered?I should then be able to measure which wire is connected to which socket in the end where the stylus is connected.
RX-2 tonearm wirering
Observing from the front and comparing to a clockface:
12 = L
3 = R
6 = LG
9 = RG
You will need to use an ohm meter to identify which wire is connected to which pin.
Thanks Mark :)
