I've replaced the motor bearings and the idler wheel of my beogram 1203. Now when I try to re-assemble I realize the #38, "transit protection device", 2938075 and #41, "transit protection device, 2938076 in the 1203 service manual are not the same. I can't tell from the service manual diagram which one is which. Also I'm afraid I've ended up with an extra washer when I'm done. Could anyone please tell if I've placed the "transit protection devices" in the correct order and with the correct orientation. Also if you could please offer any hints of where the additional washer might come from.
Login to view image
Thank you in advance!
Transit protection device in Beogram 1203
The important thing is that the motor bracket is free floating, and its
metal "ears" will not touch the nylon bushings (or you will hear rumble/whirring/running noise).
If, when you have put it all together, and the deck is in its normal upside up position,
the metal brackets are close to the bushings, you could try swapping the two bushings
and see if it ends up better centered.
There can be a washer under the nut as well.
Thank you Martin. Don't know why the service manual calls them "transit protection device", maybe something lost in translation. However, do I understand you correctly, I should make sure that there is a gap between the nylon bushings and and the motor bracket, indicated in red below? I did indeed hear running noice when I turned it on.
Login to view image
Yes, that's correct. Both sideways and up/down. The metal "ears" mustn't touch.
And it should be when the deck is upside up (not upside down as in your photo).
The bushings are actually for transport safety, because the heavy motor would be free to
swing around pretty wildly in transport, if they weren't there to limit its movements.
Thanks a lot again Martin.
Ok, I understand. What about the ears that are on the other end, in the slots in in the chassi, see below, should they also be free flowing?
Login to view image
Once, thank you so much for your help.
/Fredrik
I made yet another try at orienting the nylon bushings and was able to get rid of the noice. Success! I assembled without the wooden frame and was able to verify that the motor frame didn't touch the bushings. I took at photo and will leave that here for the next person experiencing the same problem.
Login to view imageThanks again Martin!
