Which Beogram turntable
Although I have owned B&O products since 1986, I’ve never owned a Beogram turntable and back in the days, my partner’s old Yamaha made do.
I still have a few vinyl recordings left (simply couldn’t let them go all these years) and was thinking that perhaps it is time to put them back in work and actually listen to full albums instead of jumping back and forth in playlists.
I simply thinking of getting a Beogram and connecting it to a combined NL/ML network, using an Essence MKII, so here are my questions?
1- Which of The Beograms can be controlled with Beoremote one BT, Essence or Halo?
2- Which one of the candidates from question 1 are the best you can get for money in terms of reliability and functions (in that order)?
None can be remote controlled by B&O modern equipment. Try to find a nice mint Beogram 1700 of 5000. But you’ll need a phono preamp.
Jacques
Thanks Chartz, but I believe Steve from Sounds heavenly Talks about one in a youtube clip. See blow link
https://www.youtube.com/watch?v=jq3TofitoOs
You will need a Beogram with datalink connection.
If you want to be able to control and use it with the newer stuff (Essence MK2….), you will also need an audiomaster/Beocenter, that can connect to the NL/ML Converter via Masterlink.
This is how the do it in the Beo Home (in the video from Steve).
Here - in addition - it can also be accessed via voice control….
Thanks again, MM, for the highly valued advice.
So do you mean that:
1- A Beogrma cannot be connected directly to a BS-Essence.
2- Or do you mean it can be connected to BS-Essence while controlling it remotely requires an audio master in the ML network?
3- If the answer to 2 is Yes, would any ML-enabled audio master do, such as Beocentre 2 or Beosound 4?
4- And finally, which Beogram is the most recommended turntable?
Thanks again
1: Yes, it can….but you will not be able to (remote) control it……that was what you asked for in your initial posting.
2: Yes, otherweise you won’t be able to utilize the needed datalink connection (that it where the controlling happens).
3: Yes, and furthermore any older master (e.g. a BM4500/6500….) that is connected to the ML chain using a 1611 Beolink Converter.
4: Hard to say - but you are limited to one with datalink (e.g. a 4500, 6500….), if it should be controlable via the NL devices.
Honestly - the easiest way would be to connect a turntable of your choice (you might need a riaa amp) to the line-in of a M3 or an additional Essence MK2 without connected speakers - this way it will be accessable in the NL chain……
….…you will need to place the vinyl disc physically on the turntable and turn it over after 20 minutes anyway ?
Dear MM,
Thanks once again. As always, you have been truly helpful, which I'm grateful for.
I agree: don’t bother and just enjoy pressing the start button of a nice 1700 or 5000. Or of course a 4000…
Jacques
I would hold out for a 'remote controllable' solution; there's something special about being able to control a 'mechanical' device by remote, especially if it's a Beogram ?
True. The Beolab 8000 and the pizza boxes are a joy to use and behold.
Jacques
