Well I started out looking for a pair of CX100s to go with my Beomaster 3300. Six months later I have a Beocenter 9500, Beolab 4000s, Beolab 3000s and now a very cheap Beolab 3500...
Question is this, which I think I found an answer to in the archived forums but would like to make sure before I spend the money on the wrong cables:
I'd like to connect the Beolab 3500 (Mk I, with MCL port) to the Beocenter 9500 as a link speaker in our conservatory. I'm utilising all the 7-pin inputs on the BC9500 so don't want to go down the MCL-ML converter route as (as I understand it) this takes up one of the input ports.
Am I right in thinking that I can use a single cable going all the way from the two 3-pin speaker outputs on the BC9500 to the MCL port on the BL3500, without needing an MCL2a / MCL2AV / other box along the way?
If so is the wiring layout the one shown on the attached image, from page 5 of the MCL Handbook?
Thanks very much. I realise there are loads of questions about BL3500s but I've struggled to find this answer in any of the official manuals etc.
Login to view image
