Beolab 10 in 2025
Dear Forum.
I am considering buying a Beolab 10 for a Beovision 7 TV stand. I find the sub looks spectacular. Does some of you have experience with sub in terms of soundquality? I also want to put an LG OLED 48” on the TV stand. Do you know which Beovision tv stand to go for in terms of having enough space for both OLED and Beolab 10.
thanks in advance!
The BL 10 is designed as a center speaker for use with the BV 4. The bass is existing, but not comparable to a sub. If you are looking for a sub, the B&O choices are BL 2, 11, 14, 19 and S8.
Kind regards,
Rolf
