Login to view imageI'm not totally helpless--^^this is the adapter I'm seeking information on. Name of it, part number, anything??
BeoLab 14 - HELP
Hi!
I just got a BeoLab 14 system and I'm a bit nervous as there seems to be no information or even discussion really about this system online.
I'm trying to figure out what adapters I need to...use...this system and I'm at my wit's end.
I primarily use HDMI output-sources connected to a Sony STRDH790 receiver which I formerly had a simple phono out to my Pentas.
I know I'm in a new world with an RJ45 PowerLink system like the BL14.
The key problem seems to be the inputs adapter which was of course not included--googling finds nothing at all for this specific adapter.
Can anyone offer any insight? Appreciate any help to this newbie :)
Cheers,
J
A few comments…
The BL14 system is an active (means that the ampflication is built in) loudspeaker set.
It is meant to be used with an audio device that has pre-outs or the normal speaker outputs.
That is what the adapter is meant for.
You should be able to get this still - maybe on the used market (?).
Login to view image
The RJ45-Powerlink connections are for connecting to a Beovision as the source (which is a tv with audio processing and pre-outs built in).
P.S.
My best advice would be to contact Steve@SoundsHeavenly for further advice.
You can find a link at the bottom of this site (he is a sponsor of Beoworld).
P.P.S
You can find more about the BL14 on the old forum - e.g. here:
https://archivedforum2.beoworld.org/search/SearchResults.aspx?q=Beolab+14&o=Relevance
