beolab 1700 Voltage and current adjustments
Hello - i have a circuit diagram. But cannot locate the procedures to check/adjust power supply voltage (32v) and also the driver current (not even sure what it should be!). I've been looking for a service manual and can only locate circuit diagrams.. Any advice or pointers to a service manual or just the procedures would be very much appreciated. Many Thanks Tony
Maybe the service manual for the Beomaster 901 can be used? Aren't the amplifier sections identical? I'm currently working on a BM 901, by the way.
Thank you will check that suggestion out.
