BeoLab 3 no light
Hello everyone, my BeoLab 3 no longer works. A check revealed that the fuse and two SMD capacitors in the power supply were defective. Unfortunately I can only find the block diagram on the internet. Does anyone have the circuit diagram for the power supply or knows the values ​​of the SMD capacitors? Thank you :-) Greetings
If you are referring to the SMD Capacitors around D501 they are 0.01uF C0G
