Beolab 3 to Samsung Smart TV problem
Hello, in our guestroom we got a new Samsung Smart TV and since it did not have a good old headphone socket I purchased a bluetooth connector (the TV has bluetooth audio out) to connect is to the Beolab 3. The first hour it seemed to work, but then a loud constant hum came out both speakers that only stopped by unplugging it. I also tried the Optical connecting, but that did not work at all.
What would be a more robust solution ?
Thanks in advance! Rene
ps: here the link to the TV specs:
https://www.coolblue.nl/en/product/924810/samsung-neo-qled-43qn90c-2023.html#product-specifications
RB
Thanks MM ! Guess I need RJ45 - DIN Y female cable then too?
RB
When you order you can choose the adapter cable that you’d need.
In your case the RJ45 to Y Splitter PL/DIN.
In addition you will need the regular PL/DIN cables in the appropriate lenght…..in case you do not already have some.
