BeoLab 3500: how to use the DIN connector as AUX IN
I have a BeoLab 3500 with serial 17xx xxxx, type 1601. I would like to use the DIN connection as an AUX Input. I have tried the following PIN connections (for the pin-numbers I refer to the Peter Pan picture below, so seen from the solder side of a male plug that goes into the BeoLab 3500):
  • 2 = GND, 3 and 5 for Left and Right channel IN.
  • 2 = GN D, 2 and 4 for Left and Right channel IN.
For selecting the DIN in the BeoLab menu I used:
  • 'Menu > Menu > 0 > 4 > Go'. This shows 'MCL SEL' in the display, but only gave a lot of HUM no sound coming through.
  • 'Menu > Menu > 0 > 3 > Go'. This shows 'ML ON' in the display, a slight hum, no sound coming through.
  My questions
  1. What is the right Menu operation to activate the DIN connector for AUX IN use?
  2. What is the right DIN-pin use to get the audio signal in?
You have an MK1 which has a different pinout. Have a look at little down in this thread that has the pinout for both the MK1 and MK2
Thnx Madskp! You were right. I made a new Mini-Jack to DIN cable with the pin configuration for MK1 and it worked, when connecting a battery run iPod to the BeoLab. Then I connected a streamer box via the same Mini-Jack to DIN cable, and that caused Hum on the left channel. Any idea what to do about that?
Do you run 2 separate ground wires from the minijack to the Din connector? Then maybe that could be the issue. On my testing cables I have connected pin 3, 5 and 7 (ground for MCL data) with a solder blob and just running one common ground
The cable just has 1 GND wire. The PIN connections I have now look like this:
  • 1 = Left (grey line)
  • 2 = Right (red line)
  • 5-3 = GND (black line)
  Question
  • So, do you mean I should also connect pin 7 with 3 and 5?
  • And that it should solve the Hum I am having now?
you could try to connect to pin 7 also. When the BL3500 is used in an MCL system all  three are connected via the cabeling. Also pin 7 is the only one with direct connection to ground in the speaker
Thnx Madskp. I have ordered a 7-Pin DIN plug, to include pin-7 in the grounding. Will come back with feedback when I have received and tested this.
Here's an update. Today I received the 7-pin DIN plug, so I have just soldered a new cable based on your advice. The pin connections now look like this: Result:
  • Unfortunately there is no change, I still have the Hum on the Left channel.
In this case an iPod is connection via the Mini-Jack > DIN cable.
  • When the iPod is powered by an USB wall plug, the Hum is there.
  • When the iPod is powered by its internal;l battery, the Hum is not there.
  Question: What other pin connections can I try to solve the Hum?
Are speaker and iPod charger in same power outlet ? Try that ! Try different charger. In my case I reduced 'hum' by changing charger to an iPad charger.
