- To make it switch to the external audio source, via DIN input, I use the 'Menu > 4 > 0 > Go' command.
- I make use of a Beo4 remote control.
- The BeoLab 3500 sometimes responds correctly to the commands from the Beo4, but also sometimes not. I do not recognize a pattern.
- When I remove the power plug from the BeoLab 3500 and restart it, the above described commands work at least the first time. After that sometimes not, sometimes they do.
- I removed the Beo4 batteries and replaced them with fresh new ones. > No change.
- I took another Beo4 remote (also with fresh batteries). > No change.
