How can I get the best sound out of my Beolab 5?
In my current setup, my Beolab 5s are connected to an Essence Mk2, but I would like to upgrade. I see two options:
1. Buy a Beoconnect Core and connect via Powerlink (as I understand that the Beoconnect Core does not have a digital output I can use with my Beolab 5s).
2. Buy, for example, a Bluesound Node (N530) and connect via coax to get a digital signal into my Beolab 5s, thereby using the internal DAC in the speakers.
Which option is best? And does anyone have experience with these two setups?
I would also appreciate any general comments or suggestions on how to achieve the best possible sound.
Jørgen
