Beolab 5 calibration vs power down
Dear all, During electrical storm, I usually power off my Beolab 5, and after that, I re run the calibration. Would you know if the Beolab 5 is able to recall the last calibration when power is off? Just wondering if it might be a dead battery I could change for those ma cases, but from what I see on electrical schematic, it is probably not such capability.   thanks!
Setup : BL 4000/2/3/5 mk1/20 Beoplay H6/H95 BS 4/ Transmitter 1
The BL5 will keep its calibration in non-volatile memory. The last time I read-up on this, the Mk1 BL5 could keep only 10 calibrations and needed a Dealer re-set to clear the 10 memory allocations and to be able to re-calibrate. i.e. dont do resets unless you are changing the sonic signature of your listening room. Whether this limitation was address by the MK2.....or whatever version, I am not sure?
Thank you for the technical specs. I did not know that! i did a lot of reset as we had few electrical storm risk and I did not want to take any risk. I might have saturated the memory then as I have mk1. Always impress by knowledge on this forum!
