Bo refresh the lab8's pages and add the "frequency range" Login to view image
Beolab 8 frequency range
Here is a response graph which tested by a cn kol
Login to view image
From my audition in store I am surprised to read the bass number. Even more so when compared to BeoLab 17 figures…
Frequency Range
31 - 24,000 Hz
Maximum Loudness @1m (SPL)
106 dB SPL
Bass Capability
90 dB SPL
I would say these are just marketing statistics?
im sure a 200W D-class ICE amp can deliver a lot of “oomfph” thru a 5in driver in the in the 90-250hz range but it will significantly less efficient in the 28/31 to 90hz range especially if that amp has to deliver sound at higher volumes etc…..
it’s still there but not at unlimited full-fat, unlimited quantities?
I always took that to be what they meant by the ‘bass capability’ figure. E.g. they achieve the stated (not that it’s stated to us in the spec sheet for all models) bass response up to that SPL level (inferring that upwards of that the ABL is kicking in to limit it).
Edit - turns out I’m totally wrong! See below :)
There may be some incorrect assumptions about what the terms "Frequency Range" and "Bass Capability" mean. I explained "Frequency Range" a long time ago in this blog posting: Hope that helps clear up any confusion. Cheers -geoff * It's important to remember that ABL protects the loudspeaker from clipping caused by over-excursion of the loudspeaker driver, or attempting to exceed the limits of the amplifier voltage / current or the power supply current. However, there is also thermal protection that pulls back the output of a loudspeaker driver to prevent it from melting the voice coil. If you play at maximum level for a period of time, the thermal protection starts working and the level will go down. So, the Bass Capability is the output level before that starts happening. If you're playing a sine wave, you can hear this behaviour as a simple ramping-down. However, since music & movie sound is much more dynamic, the behaviour is much more complex.PLEASE READ before sending me a Personal Message. If you have questions about or problems with B&O equipment, these should be directed through your dealer and/or B&O's Customer Service department. I cannot be a "short circuit", bypassing these communication channels. Thanks -geoffI currently have Beosound 2 and before I made my decision I have looked at the frequency range just to know which one of solo beo speakers is the best. Guess what? After listening to all of them, this one was the best sounding for my music mix. For me beosound has the deepest bass although balance and A9 on paper have similar specs. Comparison with horsepower is good, you can buy a 500 horsepower american musle car but 300 horsepower hatchbacks are just as fast and much more nimble and practical most of the time. And I have experienced it with beosound 2. I never use 90% volume nor deepest bass settings. It is just not practical in Real world to go full throttle. Most of the time I just want to relax listening my favourite music. I am looking at the Beolab range now, and I would also want to hear them all before deciding, but all other things aside, reading the specs one could think: beosound 2/a9/balance > beolab18 > beolab 8 > beosound Theater > beolab 28 Is that a thing guys? Considering specs only, and all other functions, stereo vs solo things aside. Reading just the specs: frequencies, 1m spl and bass possibilities? By the way Geoff it is so wonderful to read the thoughts of an artist about they work! I love interviews with movie creators just like I love reading Geoff thoughts about sound and Bang Olufsen has always been art for me while the others are just sound equipment.Thank you Geoff, your blog just open my mindPlease Log In to Reply
or![]()
