BeoLab 8000: dead / no red LED, measurements attached
I have a BeoLab 8000 that is dead with power attached: no red LED. It has serial number 14xx, and yes it had foam rot. I have cleaned all electronics, connectors, etc. Also I have done some checking & measuring: On the PSU PCB, I have done continuity measurements, and found no faults. Also I have measured all voltages, the result is visible in the picture attached.
  • AC in is fine, and voltages on both sides of T2/stand-by transformer are ok.
  • On the output side of the PSU PCB, the voltages are zero volts.
The Relay shows voltages that I think are not OK. What probably explaines why the voltages on the output side are zero. Question:
  • Is this just a matter of a broken Relay, or is something else going on?
You show in your diagram that T2 between pins 7 & 12 is at 231 volts. The T2 relay will NOT trigger if there is no AC voltage on Pins 1 & 3 of Plug 2 on the power supply. If there is really zero volts between pins 1 & 3 of plug 2 on the power supply, then either you have broken PCB track between the T2 transformer pin 7 and plug 1 pin 1 OR broken track between T2 pin 12 and plug 1 pin 3 OR pin 9 & 10 on T2 are not connected.
Thnx Keith! I measured the voltage between pin 1 & 3 of P2 = 44 volts AC Just to be sure, I also measured continuity:
  • T2 pin 7 > plug 1, pin 1 = OK
  • T2 pin 12 > plug 1, pin 3 = OK
  • T2 pins 9 & 10 = OK
Knowing this, what do you think is wrong?
Well, it is excellent that you have 44 volts between pins 1 & 3 of plug 2 So, the fault is either going to be one of the following:-
  1. The 24 volt relay itself is faulty, less likely, but possible
  2. The D1 diode across the relay coil is short circuit
  3. The + 15 volts is missing from the emitter of Tr3
  4. The - 15 volts is missing from the emitter of Tr4
  5. The "auto start" circuit used when using phono socket is enabled has a fault.
Check points 3 & 4 first by measuring between a ground point such as Plug 2 pin2 and the emitter of Tr3 (+15 volts) and then Tr4 (-15 volts) Measure the voltage between pins 1 & 2 of plug 3 on the power supply module If +15 and -15 volts are correct, but there is zero or near to zero volts between pins 1 & 2 of plug 3 then the "auto start" circuit may the cause.
Thanks a lot Keith! Red LED is ON again First of all, after my last checks I put the PSU/AMP-block back into the speaker casing, and connected everything back to original. Surprisingly, the red LED went ON again! So that's good. Obviously I also checked if it would respond to an audio signal, but unfortunately it doesn't. (I checked, with RCA connection as I currently do not have equipment to connect via MasterLink)   Next checks
  • TR3 Emitter <> Plug 2, pin 2 = + 15 volts
  • TR4 Emitter <> Plug 2, pin 2 = - 15 volts
  • Plug 3, pin 1 <> pin 2 = 24 volts
  D1 check I set my multi-meter to continuity/diode check and measured twice: once with the black probe on the top of D1 and the red probe on the bottom, and once vice versa. See the measurements in the picture below. Interestingly, with the red probe on the top and the black on the bottom: the relay clicks, the Amp turns on and music can be heard coming from the speakers. I found that the D1 is a type 1N 4148 diode. So I probably need to look for this one as a SMD type. Like to hear what you think Keith. Could this be the cause and is it just a matter of replacing it? Or could there still be another underlying cause?
  • Ad. MasterLink > Yes, you are right. I meant of course PowerLink.
  • Ad. Red light > Yes, the Red LED light was on at that moment.
Concerning the D1 diode Keith, can I just order a '1N 4148 diode SMD type' ?
Leave the D1 as it is. They rarely fail and it seems that you're able to trigger the system with your multimeter, So Tr1 works. It's not clear what your figures are. I guess that these 584 and 726 are mV's? As your using the multimeter in the diode testing mode. I provides you the forward voltage from a diode. The first number 584 will probably 0.584V and the forward voltage of D1. The second 726 is probably 0.726V and the forward voltage of the internal diode of Tr1 (base-emitter). This is the result of in-circuit measuring of components. This explains why the BL8000 switches on when you put the probes over D1. The multimeter uses a small voltage (mostly around 2V) to test the forward voltage of a diode. I would start by measuring whether there is a voltage on the base of Tr1 when powering on and off. It should be 0V (in standby) or 0.7V (forward voltage) on the base of Tr1. Resulting in the collector of Tr1 going down to ground level. D1 is only used to protect Tr1 for negative voltages provided on pin4 on the powerlink plug.
Thnx Beobuddy. FYI, the multimeter I am using is a Voltcraft VC130-1. So I measured between TR1 and GND/pin 2 on P2, while having power on the BeoLab 8000. So it's in standby mode, red LED on. Here's the results:
  • TR1 Base <> Pin 2, P2 = 0 volts
  • TR1 Collector <> Pin 2, P2 = 7,33 volts
  What do you think BeoBuddy, what could be the underlying cause?
