- When I play no music and keep my ear close to the speaker drivers, I can hear high frequency noise (especially at the tweeter of course).
- When I touch the casing or the AMP/PSU metal panel, there is a slight hum increase.
- Since this is a speaker with old foam, I had to clean the foam rot. So I have meticulously cleaned all PCB's (incl PCB05 and 06), components and connectors.
- I have checked for broken solder joints or PCB traces (incl. measuring continuity). Couldn't find them but re-flowed solder joints on PCB 01/02 just to be sure.
- Measured voltage output of Trafo T2: 2x 20 volts DC.
- What could be wrong?
- What should I do next?
