- The Service Manual on Beoworld is Mark 2.
- The type numbers did not change between Mark 1 and 2 so the front cover numbers are the same.
- One must look at the circuit to see the difference.
- My BeoLab 8000 has serial number 1448 8372, and is a type 6801.
- The top image shows the diagram from the Service Manual I have from the BeoWorld forum.
- The lower image shows a picture (from the same section) of the PCB of the BeoLab 8000, for which I have to solve an issue.
- Comparing the diagram to the physical board, I found that the the five components marked red (in the left blue square), can't be found in the same section on the PCB (lower image). Or at least, it just looks different which makes it difficult to understand what is what.
