- Vail Johnson – Bass solo (): Immediately from the beginning of the song, the vibration can clearly be heard. The vibration follows the kick drum instrument. NOT OK
- Bass test 20 Hz (Result: no damage or loose parts found.
Comparison test: How
- I played Coldplay Magic on 3 different sets of BeoLab 8000.
- I changed the two speaker drivers between the sets used in the test. BeoLab Set 1Set is the set where the issue started. I used BeoLab Set 2 as a reference, because I did not have the vibration issue on this set.
- Source: iPhone 12 with Spotify, connected via Lightning to RCA cable, to the RCA input of the BeoLab.
- Measuring: Spotify has 16 volume steps. I measured 4 points: a) at what highest volume step level there was no vibration, b) at what volume step level the vibration starts, c) at what level it gets clearly hearable, d) at what level it mis absolutely bad.
- A bit confusing now, because is this problem a combination of bad woofer drivers with a problem on the amplifier/cross-over filter side?
- So, what could be wrong here and what should I check?
- Pictures of the 'bad' drivers from BeoLab set 1, after I removed them from the panel to have a visual check.
