- The DAC is AC-coupled and provides a typical line-level signal (~0.9-1 V RMS)
- Standard shielded cables, 1 meters in length
- I have put 47K ohm resistors between Pin 3 and GND, end between Pin 5 and GND > no result
- I have set the volume output of the DAC to zero (to see if this could 'silence' the signal > no result
- Changing the DAC to different audio source; iPhone via same cable > the 8002 does switch back to stand-by correctly
