Beolab Penta Mk III amplifier problem
After recapping my Beolab Penta amplifiers, one of them is not working correctly.
The idle current has been set at 30 mV. However, I cannot measure any changes in DC voltage on the speaker cable. The On button is also behaving strangely - sometimes it switches to green but most of the time it stays at red when selecting either Auto, R or L.
I checked all solderins, and I am afraid that I need a little help to pin point where the problem could be. Any help is appreciated.
I assume it worked before the recap?
Post some pictures of the top and bottoms of your boards. Someone might be able to spot the problem visually.
Glitch
Thanks. I hope so.
Indeed it did work before the recap but was getting luke-warm at even low volumes so I presume the idle current was too high (or the dense layer of dust in it caused it). I have re-attached the black ground wire (hopefully to the right place - the solderpoint to the left of D9).
Login to view image
Login to view image
Login to view image
Login to view image
I hang my head in shame. I used the wrong setting on my multimeter, choosing ADC instead of VDC. So there was no problem at all. The DC current is now between 0 and -1 mV. Sorry for the thread.
However, one problem remains. The displays do not work in either of the speakers. I have them connected to a Beomaster 7000 with a Powerlink Mk2 cable, and the selector at the bottom of the speaker is on Audio. The display in at least one of the speakers worked before I recapped the amplifier and the crossover boards. I did not test the other before I started the rejuvenation.
It is good to hear that the main problem was an easy fix ;-).
It is normal for the two BF858 transistors to run a bit warm. Based on the discoloration on your circuit board it looks like the amp was pushed pretty hard at some point.
I don't use the displays on my Pentas, but I have noticed that the wires on the lower display connectors have a tendency to break.
Hopefully fixing the displays will also be easy for you...
Glitch
Yes, that area appears to have been hot sometime in the past. It was the same area in both speaker amps. I don't know the history of the speakers. I bought them from an elderly lady, and she threw in a Beolab 3500 plus cables and connectors for the quite modest price of 263 dollars for all of it. I wasn't exactly thrilled about getting the Beolab 3500 and immediately put it up for sale. However, it does not appear that it is in demand, so I guess I will mount it in my bedroom. I just need a 1611 converter box.
Glitch - can you tell me where the "lower display connectors" are found? Do you mean in the lower board of the two, or is it found in another place than where the displays are mounted?
So, it was the soldering but not in the actual connector. It was the damn Powerlink cable where the Data Ground had snatched off. After repairing the cable, the display works! Thank you for all the help.Location: Copenhagen
