Hi forum ,
i do hear digital beeps in my beolab penta's ( the communication signals from the beomaster ) ,
Is there a way to dampen these noises ?
is this common or a sign of older-age ?
beolab penta mkIII with digital noise
I've had this issue with Beolab 8000s and it usually means you're using the wrong type of Powerlink cable that doesn't have the right shielding.
Steve at Sounds Heavenly will be able to advise and sort you out with the right cables.
it is the "high quality " 5mm double shielded cable ...........................
from a reputable seller ( not ali ) .
it does not affect my hearing experience , i was only worried about the speakers .
