Beolab2 no green light looking for help
My Beolab2 wont able to switch on,it has red light only. Dissemabled the unit,checked fuses and brigde rectifiers alright.
I hv some tools available, multimeter/power supply/simply osc. Some general knowledge and experience in repairing electric appliance.
My asks:
1) does anyone has the circuit diagram pls
2) any recommendation on the most common failure component to look at
Thank you.
I am working on a similar situation. Have a look at this thread. Hope it helps.
https://forum.beoworld.org/forums/topic/beolab-8000-dead-no-red-led-measurements-attached/#post-18551
The Beolab 2 is completely different when comparing with the BL8000.
Where you easy can solve problems with the BL8000 with the available diagrams and knowledge, the BL2 is a processor based speaker where the auto protect can be triggered by different causes. Diagrams are only available on a minimal level.
