Beolab28 issuing constant white noise from one of the driver
hi All
I’m enjoying my Beolab28 without any problem … until recently
since few hours : one of the Beolab28 is issuing a constant « white noise » from one of its driver: one of the mid range (up, right) is emitting this noise whenever the speaker is ON.
- no matter which source I’m using
- the speaker is connected to router via ethernet
- the speaker is up to date (4.1.3), and I’ve factory reset it, run Room compensation again, and unpair / repaired the stereo with the other beolab
can you please help me ? I’m very worried it could be a hardware issue ??
Reach out to your local service provider or store.
Allow remote support via the app.
The store/service provider will log into the speakers and check for issues along with sending a log report to denmark.
They will need to know the serial numbers of the speakers.
Bang & Olufsen classic service centre.
Repairs and refurbishment to both old and new.
