Beomaster 3500 and Beolab 7.1 connection.
Hello
I have a Beomaster 3500 with 2 Beolabs 6000 connected via Powerlink Mk3. I recently got a Beolab 7.1.
Is it possible to connect this via Powerlink Mk3 as an extra?
Yes, you can add the Beolab 7-1 via Powerlink as an extra spkeaer, although you will only get stereo sound through all speakers, not surround sound. You need a Powerlink mk.3 cable like this one (this can connect to any spare socket under one of the 6000 speakers):-
https://soundsheavenly.com/powerlink-8-pin-din-connection/20-266-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html#/1-length-05m
Kind regards, Steve.
Thanks Steve for your reply.
I have such a Powerlinkcable (not yours) and I will try it out to use it as an extra speaker to the Beosystem 3500 or Beocenter 8500 with Beolab 6000
The Beolab 7.1 is working connecting with someting like this connecting with an Macbook to play Apple Music.
https://soundsheavenly.com/line-in-connection/102-438-minijack-to-beolab-2-7-8-10-28-and-2500-powered-trigger-kit.html#/2-length-1m
Beolab 7.1 is old, nice sound but so big. So I have to figure out where to place it.
