Hi, looking at floorstanders to replace my C75s and so considering the Beolab 6000.
My question is if I connect using the pre-amp output can I control the volume using the Beomaster?
Beomaster 5000 amp and beolab 6000 speakers
And replying to myself the answer is......yes :-)
Hi! Cool to hear this works for you. Can you talk me through the cable setup you used to connect the Be centre 5000 to the Beolab 6000 speakers.becsuse whatever I do I get crazy loud humming especially when the Beocentre is on standby.
Thank you!
Phin
