Hello everyone,
I also have a problem following the replacement of the cassette player belt.
I followed this excellent tutorial on the archived forum
https://archivedforum2.beoworld.org/forums/p/26380/290890.aspx
I heard the big "clac", but the tape is not playing. Only fast forward and rewind work, as well as auto reverse.
Can you give me a precise description of this "big clac" procedure?
I really tried in every way:
- by re-initializing the electromagnet under the belt motor: by turning the big wheel, the block with the reading head goes down then goes up.
- by re-initializing the electromagnet on the side opposite the motor: by turning in one direction, the small white wheel above the large wheel changes 2 positions and stops. Then turning the big wheel in the opposite direction, the "big clack" occurs.
Despite this, it doesn't work.
I take your advice :-)
NB: I bought a replacement belt on ebay in Portugal. Can it come from this belt which may not be completely suitable?
