Hi, I think the Mark III has two HDMI outputs, the other two have DVI outputs.
I found this:
1. Mark 1 type numbers 9600-9612
2. Mark 2 type numbers 9615-9628
3. Mark 3 type numbers 7710-7723
here: https://archivedforum.beoworld.org/forums/t/39780.aspx
Just to be sure, and assuming you have your cabling correct - could it be that the volume level setting in the menu is set to 0? Or that anything with the speaker role assignment is off? Best of luck! Johan
