Connecting a Beolab 2 to a Beosound 9000 wireless
Hi beoworld, i am trying to connect an older B&O Speaker (in this case a Beolab2) wireless with a Besosound 9000. I found a Beolink1 receiver (WISA), which should output to the switched Powerlink, which is needed for the Beolab 2. But what transmitter could be used to run the Besound 9000 as a source for that signal?   Would be thankful for any hint reagrding this problem.   Best regards 69er
Hi 69er, You will need the B&O Transmitter 1 connected to the 9000, then a B&O Receiver 1 connected to the Beolab 2.  Please use two RJ45 to Powerlink cables for the connections (one for each device):- https://soundsheavenly.com/bang-olufsen/31-325-rj45-to-powerlink-compatible-all-in-one-cable-convert-new-2013-ethernet-powerlink-to-traditional-8-pin-din-powerlink.html#/9-length-18m Kind regards, Steve.
Hi Steve, thank You very much for your help. Much appreciated. Best regards (from a youtube follower - i learnt so much from your videos) 69er
Thanks 69er! Kind regards, Steve.
