This is my version 3 of the STL-file to print on a 3D-printer so you can make your own wooden frets on your Beolab 2500.
Print it out and drill holes in it so you can use the original screws to put it on your Beolabs 2500 after removing the fronts. I have tryed to make it to make it reversible.
You will need 2 printed STL for one speaker and 4 x 18 x 330 mm wooden frets.
So you need:
- STL-file
- A 3D-printer and print 4 stl-files (I printed it with ABS medium)
- Wood 4 x 18 x 330 mm for every speaker 22
- Some double-sided tape for the ones on the side.
