How to Connect Beolab 14 to a streamer and a TV
I have Beolab 2.1 system and used to connect wireless with phone and Ipad to play music and TV was also part of the system. All were connected with Playmaker. Now my playmaker seems to be "dead" and I should replace it with something.
All remain the same except that I now have a Samsung Frame with optical and HDMI (arc also).
What would you recommend for me for this setup?
This one may be an option:
https://hallaudio.com/en/produkter/traadloes-streaming/hall-wifi-streamer/
Hi Tommi,
Either the B&O Core (if funds allow) or the cheaper Connection Hub should work well for this. The Core has a streamer built in, whereas the Hub has optical and analogue audio connections to allow you to connect a separate streamer as well as the TV.
Kind regards, Steve.
Thanks for the suggestion, really helps!
Thanks for the advice!
This is a new model for me, but certainly a valid option.
Tommi
