Hello,
I bought a Beolink 7000 second hand with the hopes of getting it to work. It did not come with the charger, so before I decide to get one I would like to make sure that the remote actually works. However, when I connect an "external battery pack", the blue display blinks white lines where I assume the text will be and the remote does not turn on (only the blue display blinking, nothing else lights up at all). The batteries I'm using are 5x 1900 mAh IKEA Ladda batteries, straight from the charger. Thanks for any advice given!
Regards Marckus
Beolink 7000 Blue Display Blinking
