BeoLink 7000 not moving down
Hi, I have a question regarding the BeoLink7000 which I haven't found an answer in the manuals. The BL moves up when touching the bottom plate and operates as normal. However, it is not moving down at any time after I stopped touching it. ONLY if I lift up the bottom so that the 2 pins loos contact. Any help appreciated. Thx, Jens
There is a setup option "move". Automatic and manual. But this behaviour is not quite normal. Mine does not move when waking up. Maybe the lithium Battery is going bad... BL7000 has a 6V Batterie AND a 3,3V lithium cell...
Thx. I have switched AUTO = OFF. Now I can at least manually control the movement.
When in Auto mode, it will only move the upper panel down when you lift it up from the table. If you want it to lie straight on the table you must do it manually.
