Thanks - I’ll give this a go - basically using the BLP and passive speaker as an active speaker directly connected to the BLC. really though; I can’t understand why the BLP connected via ML isn’t working.Well I tried the above setup - initially with a Beolab 8000 connected to the powerlink connector of the BLC and weirdly, the only source that worked came from the Beosystem 4 - but I di get NETRADIO coming through the speaker. On disconnecting the powerlink and connecting it to the BLP with Beovox 1s attached - the BLP didn't even power on. I'm at a loss to understand why as surely the BLP should activate if it senses a signal on the PL.Please Log In to Reply
or![]()
BeoLink Converter NL/ML
