Hi
I have a BLI that controls my Masterlink setup through a BLGW, it works perfect although I have a few challenges.
I can’t receive a LIGHT command like I did when I used BLGW as primary unit..the only command that is received is………
"23-02-23 11:31:31 Resource found Event received on unknown resource MasterLink room (9)"
The other issue is I use the command LINK DTV to activate Tunein from the main room on my Beovision 7-32, on BLGW it was possible to send that command, but I can’t find it when using BLI.
any suggestions?
Søren
Controling ML through BeoLiving Intelligence
