Making BS9000 CD source accessible with BeoLink Converter NL/ML (BLC)
Dear all. Thank you for all the great information. Really helpfull for hobbying with all the Bang and Olufsen possibilities gives us long term. After reading relevant posts I could not really find the solution for my new setup. Therefore, I am hoping for some expert knowledge. I had this fully wired ML setup:
  • BL7-55MKII in option 2 with speakers
  • BL9000 MKII sw 2.1 in option 0 without speakers. Chromecast Audio as A.AUX/TAPE/PHONO input for Audio Streaming distribution.
  • 2 BV's6-26 9290 (HDMI version) in kitchen and bedroom
  • BLGW linked parallel in the ML chain
  • Bought a BLC together with the BLWG for future use, but was not using it
Last week I bought a Essence MKII together with another BLC. My first steps in the NL/Multiroom world! First install:
  • added the BLC to the ML in parallel like the BLGW and wired it to the NL network
  • added the Essence to the same NL network without speakers and without IR eye
  • linked the Essence to the BLC in the Beo App
  • setup the BLC as AudioMaster as this was the only way to distribute audio over ML
  • discovered all devices in the BLGW and added the BLC and Essence as Networklink products in de BLGW with all Essence resources visible
As expected this gave problems because the BS9000 was already the dedicaded AudioMaster and is not programmable otherwise. Result: the commands RADIO, CD and A.MEM(/A.AUX/N.MUSIC/N.RADIO) started the sources on the BS9000 and not the Essence resources. Simply turning off the BS9000 is a workaround for this. That is actually my current setup. But I really like to use the BS9000 instead of only looking at as a work of art. My next try to get it working:
  • linked the BS9000 with ML to the BLC, no direct connection with the ML network anymore
  • BLC wired to the NL network
  • BLC setup as A.SLAVE
Result was that I could start BS9000 from the NL side (Beo APP, Beo Living APP), but the ML devices did not react anymore and therefore no audio distribution to ML. Now I am puzzled and in need for some expert knowledge if there is another solution. My best guess from all the information is to link the BV7-55 directly to another BLC. The BV7-55 resources will be visible in NL and vica versa the BS9000 resources are visible for the BV7-55 as if they are NL recources. If this best guess is the solution, I still have additional questions:
  • BLC BV7-55 as Audiomaster or VideoMaster?
  • BS9000 as VideoMaster or AudioMaster?
  • Or both as A.SLAVE or both as Source Centre?
  • Which Product by Apps should the BLC control? (VideoMaster, AudioMaster or even the Beosound Essence)
Hope all is clear enough to give your thoughts. Looking forward to your feedback.
https://forum.beoworld.org/forums/topic/beosound-9000-type-252x-from-april-1996-software-update/ mention something about which type numbers can have which software version, and there is also a guide on how to perform the upgrade.
If f.e. a BS9000 is connected to a BLC in  a NL setup it doesn't have to be compatible for N.Music/N.Radio.
All solved now. Thank you so much for your feedback! My first and second try was only one way (all ML > BLC > NL) or the other way (only BS9000 ML > BLC > NL). This step is the both ways and that did the trick. Now all works as I like it to be and as it should be for regular users like my family members. I could even source the BS9000 Radio source to N.RADIO (just for fun). I was aware of the N.RADIO/N.MUSIC sw problem. But if the BS9000 is out of the ML chain as Audiomaster, like it is now, all BV's are new enough to work around that. Also the chips with later sw is only for sale for the BS9000 MKIII as far as I am aware of. Also interesting to know, the IR mapping of each BLC is only for the BLC itself. As I am not using the IR eye, those settings are obsolute untill you attach an IR eye. Those BLC's are pretty nice devices once you get them to know. Will try find some extra ones. Especially for linking a future BLI to the BLGW, but maybe also to make all current sources visible as networklink sources in the ML devices in the BeoLiving app. Thank you again. Kind regards, Peter
Good afternoon all, In the meantime I tried another solution to extend the possibilities. Especially for the Beoliving app/BLGW to make the playing source visible and only show those sources in the app. I tried this:
  • BS9000 ML >  BLC > NL (as A. Master or V. Master)
  • BV7-55 ML > BLC > NL (as V. Master of A.Master)
  • Beosound Essence MKII > NL (the start of this all)
Of course the BV6-26's could not see or control the BS9000 nor the BV7 sources anymore, as both are still in the old ML chain. Would connecting a seperate BLC per BV6 as A.Slave be the solution for this? But also between BS9000 and BV7-55 it did not work like a charm. For example the sources from BV7 stayed visible as actual source visible playing in Beoliving ("DTV is playing on BLV BV7-55") , even if I switched to Deezer and was actually playing Deezer. Switching sources on joined product freezed up the app, etc, etc. Anyone ideas for a better solution?   Best regards, Peter
