Master link Audio Master
what is the easiest way to add the signal in Masterlink to convince other devices that a ML Ausio master is attached?
I note that in the ML/NL converter you can get a box that will do that, but what does it do?
maybe it would be easy to make one? Any idea of what voltage and what wire on the ML connector is needed?
I think what you are saying is that if I attach a 1611, then I won’t need an audio master? I’m not using datalink, just ML and NL.
I think that would be the case depending on your setup and goal. My knowledge of the ML/NL converter is limited, so my answer is for the ML part.
in the linked thread it was tested with both Beolab 2000 and 3500 as well as different Beovisions and a Beport without other components in the Masterlink chain.
Thanks.
