MasterLink USB adapter
Sounds interesting ?Great, thanks for confirming. Meanwhile I created a block diagram of the solution in question. More or less copied over the audio block form the universal link adapter project. Just added a simple USB I2S bridge. While there are several other ways implementing it on the audio side - those two chips (ADC & DAC) are working well with ML and only require minimal surrounding components. For ML master/slave selection I probably just add a manual switch on the board. I see no application where this needs to be changed programatically during runtime... Login to view image...Please Log In to Reply
or![]()
