MLGW and BL3500
Hi All
I’m thinking about buying a Master Link Gateway, but it seems like in order to use it with BeoLab 3500 you need a firmware version 3.3 or higher, my BL3500 are firmware version 2.0 and I can’t find any PCB36 with FW 3.3, also I have 5 of them so it would be expensive.
Can someone confirm, that it won’t work with the lower FW versions before I buy a MLGW?
Best regards
Christian
Did you see this thread which may be helpful depending on your planned usage?
https://archivedforum.beoworld.org/forums/t/39994.aspx
No I did not ;-) so thanks for the link. I need to use the home automation and macros, so as I read it the BL3500 needs to be updated.
Does anybody know if the PCB36 still can be bought?
The last post in that thread mentions B&O part number 8006039
Maybe give AVA Services a call and see if it is still available: https://www.avaservices.co.uk/
Thanks ?
