On/off macro for BeoLink Gateway
Hello.
I just have a question that I hope someone can help with.
I'm playing around with getting a BeoLink Gateway on my system at home.
Can I make a macro where I can switch a light group on and off using the same button on my BeoRemote One (eg green)...?
Thanks in advance
Also, just in case you might control your lights (and home for that matter) via homeassistant: there's a cool plugin for homeassistant that effectively receives all the traffic on the ML bus. Each event on the ML bus creates a trigger in homeassistent. With this you can easily program actions in homeassistant which catch beo4 key presses and trigger whatever you want in homeassistant.
cheers
-tb
