Hello Did not find a thread on this topic. I like to be able to listen to the Radio BS9000 SW2.2 located in the living room, on my BV10.40 located in the bedroom Can I add a second ML/NL converter in the bedroom, instead of installing a ML cable? (one is already installed in the NW room) The wireless ML is not working very well... Or must I upgrade to a BV11? Thanks // Håkan
Hello Håkan, That should work fine. See my setup where I also linked a BV10 through NL. Let us know how you move on :-) Regards, Johan
Thanks I will check after I done the purchase BLC = ML/NL Converter, correct?
Hi Johan Out of interest…….which (audio) sources are you able to use, when at the BV10? And how do you start these with the Beo4? MM
Hello MM, See below the configuration. Downstairs I use the Core for Radio, but in the 'Study' (=attic) there is also the BS5. When playing radio on the BV10 I like the visual of the BS5's screen to show the station :-). The Beo4 commands are from the 'ML source' listing. The BV10 and it's 'own' Beo4 are in LINK mode as I also use the BC6 (that is close to my desk) to play from the BS/BM5. Have a nice Sunday! Regards, Johan
